HP EliteDesk 800 65W G3
LAD
New member
Please help me to decode or remove bios password to my HP EliteDesk 800 65W G3 Base Model Desktop Mini PC.
If someone can help me crack the password, will I of course buy my own LBE++ >;0)
LAD
New member
#3
Please excuse me. I am a Noob to HP pc. (i am a Dell guy >;0)
I use HPBIOSUPDREC64.exe and option create Recovvery USB flash drive.
It seems that the only file that is saved is the bin file I send.
Am I using the wrong program when trying to copy the bios?
Please guide me in right direction.
LAD
New member
#5
I understand. Thank you very much for taking the time to help me!
Is a CH341a MiniProgrammer good enough, or should I use something better?
LAD
New member
#7
You were absolutely right. It was not easy to get stable readings with the CH341a. On my first attempts, I got different results on each reading. Today I succeeded a little better and managed 4 readings with the same CRC value. ((Just to be safe, I checked the files with "certutil -hashfile biosRead.bin md5" and all the files had the same MD5 hash).
Do you have the opportunity to look at the attached file if everything is ok?
