High Pressure Water Misting System manufacturers
High pressure misting system for odor control
Working Principle
The Ucloud® High-pressure misting system for the odor control uses the high-pressure pump to increase the pressure of the liquor(with the fixed mixing ratio) to 50-70 kg, then goes through the high-pressure pipeline and is sent to the high-pressure nozzle atomization to become the fine water mist. Because the water mist particles are in microns- very small, able to adsorb impurities in the air to create the fresh air, to achieve the dust suppression effect. With the special liquor, it can achieve the purpose of deodorant. It is multi functions in a variety of applications. The system has a very significant effect on the garbage transfer station, garbage removal station, landfill, sewage treatment and other odor environments. With the spraying gun system, it can also achieve the role of cleaning and disinfection just need one machine. The system is economic with low operation and maintenance costs. With the control system, it can be automatically controlled.
High pressure misting system for odor control installation diagram,
Main Features
1、Automatic Liquor ratio:The system included the doser with automatic liquor ratio function. The adjustable ratio-valves, automatically siphoning type, automatically ratio to make sure the liquors spray out in a fixed ratio.
2、High effeciency:Deodorization efficiency is up to more than 90% .
3、Fine Mist: High-pressure water misting nozzle can produce 5 billion droplets per second with the droplet diameter of only 5 to 20μm. The mist can quickly cover the space with no dead angles. The deodorant effect is excellent.
4、Cost saving: Atomizing 1 kg of water consumes only 4W of power. It is 1% of the traditional electric humidifier, 10% of the gas-and-water mixed humidifiers.
5、Steady and reliability:The main part is the Industrial use Piston
Pumps imported from the overseas. It can continuously run for 24
hours. There is no wear parts for the misting nozzles and Water mist dispense. It can work in the high dusty environments.
6、Safety:When the system stop working, the auto-pressure-releasing valve will release the pressure in the pipes to avoid the water dripping problem. The self-shut-off system can avoid the pump damaged because the lack of water.
7、Spraying Volume:From 50kg/h to 1500kg/h adjustable, can achieve automatically control.
8、Frequency converter: Automatically constant pressure water supply, according to the start and stop state of each areas, it can automatically adjust the pump pressure, effectively protecting the water pump and pipeline in safety.
9、Advanced new technology:To avoid the water gathering, water sediment and Water moss problems, and make sure the spraying effect, the spraying nozzle heads are with water-dripping-prevention function.
Installation Diagram
(1) inlet valve
(2) Water filter
(3) Humidifier
(4) Computer Control System
(5) high-pressure control valve (manual or electric)
(6) Mist Nozzle
(7) High-pressure Tee joint, Cross
(8) High pressure pipe
(9) Plastic wire rope
(10) Temperature and humidity sensor
(11) Chiller (optional)
(12) Ion water softener
(13) High pressure check valve
(14) High pressure electric valve discharge system
Technical Parameters
According to the customers
The Machine Appearance
website:http://www.huayunhumidifier.com/high-pressure-water-misting-system/
