Report LBE starting error
egyfixlab
Administrator
Staff member
Board Admin
hi all LBE Folks
when ever you have error in Lunching LBE software Please Follow these steps
1- Be sure no hardware Changes Done
2- if LBE still not work then go to LBE Support and Create Technical Support Ticket
in this Link
http://www.egyfixlab.com/laptop/forums/technical-support-ticket.92/
be sure to create new Key in Same LBE Runing Machine and Load in your Ticket
Luay Abbas
New member
LBE-BASIC
#4
thanks but Unfortunately after creating a new key it asks about MEPath and if you write the program's path it comes back to the first problem just shows up for a few seconds then vanish (doesn't work)
start technical support ticket and create new Key
we will fix it for you
egyfixlab
Administrator
Staff member
Board Admin
#5
there is no any issue with ME Path you can set ME Path as you like this will not effect on software start
the only reason for prevent LBE from start is hardware issue
Luay Abbas
New member
LBE-BASIC
#6
i started technical support setting but i dont know where i can find my old key file to attach it
luis amaral
New member
LBE-BASIC
#7
removing all usb hubs , helped me out , but this is kind weird , i have to shutdown many hardware in order to put in working ? perhaps next update chek that out !
